how smart is a smarty?
Old Nov 26, 2010 | 10:25 AM
crazycooter's Avatar
Default how smart is a smarty?
I am looking at programmers and such, and am aware of the smarty being able to read diagnostic codes... not necessarily a key feature for me being that my odometer will give me most of them, but will a Smarty read the codes out of the abs computer? (my abs and brake lights have been on since I bought the truck)
Old Nov 26, 2010 | 03:15 PM
DanLowe's Avatar
Sounds like a speed sensor...mine did the same thing...not that it has anything to do with a smarty...
Old Nov 26, 2010 | 05:28 PM
oudive's Avatar
crazycooter,
I have a Smarty and mine only reads the DTC codes. I have heard and read some where in a forum that by jumping certain pins you could get the ABS light to flash and then just count how may flashes and then look it up. I have not tried that nor have I tried to look anything further up on it. I think that a scanned from the Actron line is designed for the ABS but it too is a pretty penny.Hope that helps answer your question.
oudive
Old Nov 27, 2010 | 09:16 AM
maybe for the cost, I can have the dealer tell me what parts I need to buy from them to turn off the lights...
Old Nov 27, 2010 | 05:39 PM
scottsjeeprolet's Avatar
Go RAVENS!!!!!!!!!
It's the ABS sensor on the rear end. $43 from Autozone and 10 minutes to install. Dealer will probably charge you a fortune to do it.
Old Nov 27, 2010 | 09:13 PM
if its my rear abs sensor, (btw i have one behind the seat somewhere) then how does it not affect my speedo? being it is a multi function sensor
Old Nov 27, 2010 | 10:27 PM
Go RAVENS!!!!!!!!!
Look we have all had the exact same problem on the same trucks. I just did mine last month. ABS light, Brake light on. Changed the sensor and it's fixed.
Old Nov 28, 2010 | 08:38 AM
i guess Ill let that one float on up to the top of my $#!+ to do list, thanks
Old Nov 30, 2010 | 06:22 PM
springer's Avatar
mine was the abs wire rubbed on front rotor and got cut. May want to check that.
nomoney
13
Sep 26, 2015 12:04 AM
05cumminsCA
8
Feb 3, 2015 09:29 PM
jdepuy618
For Sale
Dec 21, 2014 05:28 PM
