bragging rights?
Old Nov 24, 2010 | 05:00 PM
zielinski.family's Avatar
Default bragging rights?
What is the average size load you put behind your 6.5? What is the biggest?
Old Nov 24, 2010 | 05:26 PM
mud's Avatar
mud
pulled my buddys semi. wout trailer out off snow bank took some work but she did it!
Old Nov 24, 2010 | 10:11 PM
Crazy's Avatar
i pull a 16,500lb 5th wheel with over 300,000 miles but had trans rebuild 1.5 ys ago
Old Nov 24, 2010 | 10:21 PM
94cummins diesel's Avatar
i pulled a dodge 3500 dually with my truck single cab 2wd on a trailer did pretty good for what it is now its time to strip it down an re build i blew the block up an the head gasket o well she will be built up this yr good
Old Nov 24, 2010 | 10:42 PM
Crazy's Avatar
well you should not pull with dodge
Old Nov 25, 2010 | 09:05 AM
the warden's Avatar
i took an allis chalmbers 200 on a 24 foot goose neck over 400 miles down state and she pulled just as good if not better than our 97 ford f250 with the 7.3 the tractor was 7,324 lbs and im no sure wha te trailer weighed
Old Nov 25, 2010 | 12:10 PM
Woody35's Avatar
4 thousand pounds
Old Nov 25, 2010 | 06:37 PM
2MuchJunk's Avatar
Too much for a light duty 3/4 ton. Pulled one semi loaded with steel out of the snow. The heaviest load I have a number for was a fork lift that weighed 16,000lbs but I don't think that it weighed as much as a old 2010 John Deere crawler with backhoe I used to have. The most I usually tow with it is a fork lift that is 12,500lb. The old truck doesn't do bad and now has over 300,000 miles of abuse on it.
Old Nov 27, 2010 | 12:07 AM
tyler111991's Avatar
I have pulled a goose neck loaded with scrap metal that weighed just under 7000lbs, but thats about the most i have done
Old Nov 27, 2010 | 02:18 AM
FastCR's Avatar
I pulled around 5k with mine but beat my dad in a drag race driving his fairly hot tuned 7.3 with less of a load when my 6.5 was modded at its prime.
