Tranny Issue
Old Nov 23, 2010 | 07:49 PM
Shoe's Avatar
Default Tranny Issue
Hey everyone, i recently bought myself a 1st gen but found when traveling on the highway at a faster speed once i accelerate so much it wants to shift down even when im not pulling. Need some advice on the fix.
Another thing is the speedometer is way off. i noticed it is electrical and i do have 35s on it. Does the adapter need relpaced or is it the gauges?
Old Nov 30, 2010 | 09:16 AM
Diesel power's Avatar
is it doing it even when your not on the fuel? maybe your kick down cable needs to be adjusted.
Old Nov 30, 2010 | 06:19 PM
Shoe's Avatar
No only when im on it. Once i reach a certain point it will shift down or say i floor it it will shift down also.
Old Nov 30, 2010 | 06:26 PM
RAW's Avatar
RAW
More than likely the shift down cable.
Speedo needs to be changed in the PCM via a programmer or dealership programmer.
Old Nov 30, 2010 | 07:35 PM
kieron_kohlmann's Avatar
its your spedo. you can buy the adapter from BBD($100). the dealership can NOT program tire sizes in our trucks like they can with newer vehicles.
Old Nov 30, 2010 | 08:34 PM
Default Re: Tranny Issue
Superlift makes a fix.
Sent from my Droid2 @ 1.4ghz
Old Nov 30, 2010 | 09:05 PM
sweetv8s10's Avatar
The down shifting problem is probably the throttle position sensorer because my 92 done the same thing but I dont know about the speedo.
Old Nov 30, 2010 | 09:12 PM
Mine was going the same thing around freeway speed if you gave it, it would pop out of OD. When i got my spedo working that went away. Id try the spedo first since its $100. a new TPS is $300 unless you buy the potentiometer kit its $30.
Old Dec 1, 2010 | 05:54 AM
Shoe's Avatar
ok. thanks eveyone. il take a look and see what i can do.
85IDI_International
Apr 24, 2015 01:08 AM
wilki
Feb 12, 2015 09:04 AM
Adam65
Nov 22, 2014 11:58 PM
Trevlar11
Nov 16, 2014 01:59 PM
Oct 23, 2014 08:10 AM
