Fuel line leaking...
96 dodge 1 ton.... One of the fuel lines going to the fuel filter is leaking right above the front of the bellhousing... Simple enough to fix except I'm not sure what would be the best way of getting to it... Sadly with my big a$$ hands I think I'm goin to have to pull the brake booster off... Any suggestions for another plan of attack?
I just did the same thing. Jack the truck up remove the driver side tire. remove the fender plastic. Then you can see every thing. Get to every thing. I think you can get those little plastic pins at the dealer. i used zip ties and a few bolts. If you take your fuel filter off and change it. you can see even more. good luck.
