Crack in Fuel filter header/assembly
Old Nov 23, 2010 | 12:36 PM
dieseleagle's Avatar
Default Crack in Fuel filter header/assembly
Hello all,
I have a 94 7.3L IDI and found a crack in the Fuel filter manifold. Is there an easy fix, cause I am having a heck of a time trying to track down a replacement. The number on the Assembly is 1809433C1 made by International. Thanks
Old Nov 23, 2010 | 02:28 PM
DieselCrawler's Avatar
where are you located? i have 2 for 6.9 and i think one for a 7.3.
look in junk yards.
Old Nov 23, 2010 | 02:35 PM
Located in AZ I need the on for 94 7.3L IDI
Old Nov 23, 2010 | 03:13 PM
any local yards? i will go dig threw my stuff. see if i still got it.
i have one if u cant find one used. 25 bucks plus shipping?
Last edited by DieselCrawler; Nov 23, 2010 at 03:13 PM. Reason: Automerged Doublepost
Old Nov 24, 2010 | 01:59 PM
Looks like the O ring is bad for the fuel heater. It looked like the fuel was coming out of the seam on the filter assembly. I cleaned all the dirt and grime off and ran it for a while and its leaking out of the back of the heater port. How much am I into on replacing the O-ring. It does have cold starting problem. I found that my glow plugs are bad and looking to change them out this weekend.
Old Nov 24, 2010 | 02:22 PM
make sure u only put motorcraft or IH plugs in. all others have a tendency to swell and break off. do a search on glow plug removal, i posted before directions so if a tip does break off it wont drop into the cyls.
there is an o-ring that seals the heater connection off. They dry out and you end up with a leak. International has these o-rings for around $2.00 each. All you need is one. Its easy to replace. First remove the filter. Then remove the wire connecter. Now use a 1 inch wrench on the filter internal threaded mount. When thats off the heating element will drop down. Then dig out the bad o-ring with a dental pick tool carefully as to not do damage to the aluminum housing. Install a new o-ring and grease up the heater connecter that fits back up in the head. Return all the removed parts and your done... The part number is 1811053C1.
hope that helps
jeffersonl
Nov 15, 2015 07:35 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
