Cummins 4BT w/ Ford ZF Transmission
Old Nov 23, 2010 | 12:56 AM
47Ford - 1.5Ton's Avatar
Default Cummins 4BT w/ Ford ZF Transmission
FOR SALE: Cummins 4BT & Ford ZF Trans 2WD Combo
NOTE: Lets get this out of the way. Will not part out, will not separate, no trades, notta.....
3.9L Four Cylinder Cummins 4BT
CPL 858
**Turbo H1C
**Alternator
**Ford SBF Trans. Adapter
**Starter
**Starter Spacer
**Saginaw 'Canned Ham' Power Steering Pump
new valve cover gaskets, intake, and oil pan gaskets
Ford ZF S542 5 Speed manual OD Transmission (2WD)
**Cannot VERIFY actual operation but I personally pulled from F250 w/ 140,000 miles....(I never drove it )
**New LUK Clutch
**New LUK Slave
**New flywheel input bearing
**Ford SBF Flywheel
**New Ford Clutch Master Cylinder
**New Ford clutch master cylinder line (did not get it cut up to use the new ends on a custom made hose)
(Any misc accessories I may have missed or per request - motor will come with GM breadvan tilt motor mounts attached)
$3000 FIRM (This is a steal guys, sorry not going to budge)
Will consider shipping at buyers expense and arrangement......
Any questions, just ask!
~M
Old Nov 23, 2010 | 05:35 AM
Diesel Dummy's Avatar
so i take it you decided to go to the big block instead!!! Good deal on a small block setup for sure!!!
Old Nov 23, 2010 | 04:15 PM
I6_or_die's Avatar
FormerVendor
bump for a hell of a deal!!! looks like a great set up man good luck with the build and the sale!!
Old Nov 23, 2010 | 05:24 PM
Yup, just looking to move it fast..... its worth $4000 easy so I'm assuming 3 should make it go quick I hope. Want to keep the 1947 and 6BT project moving forward.....
Old Nov 26, 2010 | 04:19 PM
Sale Pending, no longer accepting purchasing inquiries at this time.........
Dzljon
Diesel Engine Conversions
47
Jul 30, 2016 04:05 AM
atreefunk
For Sale
Apr 13, 2015 10:57 PM
pointb912
Jan 17, 2015 01:54 PM
Nov 4, 2014 01:30 PM
