Pulling
Old Nov 22, 2010 | 09:36 PM
leroyb1138's Avatar
Question Pulling
I slid the fuel plate and i pull a bobcat alot and was woundering if the smoke screw would help me out any?
Old Nov 22, 2010 | 10:44 PM
Red_Rattler's Avatar
High Tech Redneck
As in more power? No... Take the plate out and grind it into a number 10 and see what that does for ya
Old Nov 23, 2010 | 12:22 AM
12vcummins96's Avatar
yep i agree every truck is different
Old Nov 23, 2010 | 07:42 AM
leroyb1138's Avatar
How do you grind the plate and will it hurt it
Old Nov 23, 2010 | 08:12 AM
High Tech Redneck
You need to do some searches and alot of reading! Start here https://www.dieselbombers.com/5-9l-1...-12-valve.html
Also you'll want to get at least an egt gauge in ur rig b4 u mod it any further! Also has the kdp been done yet? If not search kdp for alot of good info...
Old Nov 23, 2010 | 09:01 AM
leroyb1138's Avatar
I know how to grined it i just dont know how far to go and whats kdp
Old Nov 23, 2010 | 11:11 AM
High Tech Redneck
Search Killer dowl Pin
Old Nov 23, 2010 | 12:13 PM
BRE's Avatar
BRE
x2 on the dowel pin. You wont be happy if it decides to exit the block via your timing cover.
Old Nov 23, 2010 | 02:52 PM
leroyb1138's Avatar
Thanks 4 the pic that helps but the smoke screw would it hurt the motor
Old Nov 23, 2010 | 03:43 PM
High Tech Redneck
All it does is add low boost fueling... Hence the name "smoke" screw. It has nothing to do with adding over all useful power. Just smoke and egts climb sooner and faster. Kind of the opposite of what u want when your towing.
