60lb valve spring questions
Old Nov 22, 2010 | 08:45 PM
dipapadakis's Avatar
Default 60lb valve spring questions
i just ordered me some 370's and now that i can fuel more im looking at valve springs i already have 4k gsk's but was wondering the difference in just doing exhaust vlave springs or both exhaust and intake srings? is it better to do all 12 or do you just really need 6 to be able to redline near 4k? any advantages in doing both?
thanks
Old Nov 22, 2010 | 10:48 PM
Red_Rattler's Avatar
High Tech Redneck
You need all 12, the exh only set is if you have a exh brake only...
Old Nov 22, 2010 | 11:03 PM
12vcummins96's Avatar
you have to have all 12 to spin 4k
Old Nov 22, 2010 | 11:27 PM
thanks guys
Old Nov 22, 2010 | 11:30 PM
Benjamin's Avatar
Bombardier
BUT with all that fuel and a stock turbo valve springs wouldn't be on the top of my list of upgrade parts.
Old Nov 23, 2010 | 11:48 AM
Smokem's Avatar
You only need exhaust springs. I would not spend the money to buy 12 60psi springs, there are better options if you wish to do all that work.
Old Nov 23, 2010 | 12:17 PM
BRE's Avatar
BRE
Smokem would you care to elaborate on this a touch more? You hint around like there is a way to steer away from the common role of just buying someones 60lb springs and putting them on.
Old Nov 23, 2010 | 12:53 PM
Smokem's Avatar
Yes, there are better options. But it will require replacing all valve springs, locks, and retainers. If you do not wish to go that far, just get 6 springs for the exhaust side.
Old Nov 24, 2010 | 09:03 AM
daveO's Avatar
If you're spinning 4k, why are you not worried about valve float on the intake valves? I figured it would be just as likely.
Old Nov 24, 2010 | 02:54 PM
Smokem's Avatar
Because the piston isn't chasing the intake valve closed.
