Head Gasket leak - I'm going to BOMB it.
Old Nov 22, 2010 | 06:01 PM
Deleted09's Avatar
Default Head Gasket leak - I'm going to BOMB it.
The head gasket started leaking last week. The overflow is full, and truck looses coolant steadily. I am using Smarty with the DPF deleted, and now I put it on SW 0 to try and reduce pressures.
I was running it on SW 1 or SW 3 before it went, just normal use, not even towing, and only 12000 miles on the truck.
So, I am going to delete the EGR and the cooler, and add some parts for more airflow.
The first thing will be ARP studs, I am using the 425's, they should be better than stock.
Next is the EGR cooler delete, and I am going to add a grid heater delete.
The grid delete gives better air flow, but I live in Canada, eh.
So, I am adding a throttle valve delete, that includes a grid heater, but with much better flow than the stock heater. The parts are on order from Glacier Diesel.
That should eliminate all the Dpf -EGR from the truck, and next will be a wastegate.
I am going to start wrenching on it tomorrow.
Old Nov 22, 2010 | 06:09 PM
crzycummins's Avatar
hopefully you have some gauges in there somewhere
Old Nov 22, 2010 | 07:12 PM
Deleted09's Avatar
I will definately need a boost gauge, EGT gauge , are any other gauges recommended? Is there a drive pressure gauge? I am using Smarty ME 14, so I will just use SW2 or 4.
Old Nov 22, 2010 | 09:12 PM
tranny temp...guess a rail pressure if ya want.
Old Nov 22, 2010 | 09:16 PM
dodgeram082500's Avatar
Those guages will be ok for some things but one question how far are you planning to push your truck 500 HP? 700?
Old Nov 22, 2010 | 09:35 PM
Deleted09's Avatar
I'm looking for about 500 hp, without a turbo or injector upgrade, should be no problem. That power level will likely delete my stock clutch pressure plate.
I want to keep that drive pressure down, and not blow out the HG again. I am going to use the Pro-gate wastegate from Glacier diesel. It hooks in to the EGR ports on the manifold, and can be adjusted. This unit is probably overkill for a stock truck, but will be there if I ever want a higher HP level
Old Nov 22, 2010 | 10:15 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
the 14me is a head killer. im running 22 now. they have 23 out too.
Old Nov 23, 2010 | 12:03 AM
Make sure you use a "Genuine" Cummins Gaskit Kit. Not a cheapo placed inside a Cummins Box sold as a "Genuine".
Luke
Old Nov 23, 2010 | 12:31 AM
99stackedpowerstroke's Avatar
so what smartys are good and are bad on the 6.7?? my brothers got on and hes wanting ta buy a smarty jr. this will be good info for him haha,
Old Nov 23, 2010 | 07:17 AM
diesel pap's Avatar
any smarty that has the latest update is fine.
