6.2l diesel need help getting it started
Old Nov 22, 2010 | 04:49 PM
92typhoon937's Avatar
Default 6.2l diesel need help getting it started
ok so i had it all apart and had the injection lines off to replace the valve cover gaskets
ive cranked it over a good bit with the lines cracked open at the injector and still dont have any fuel coming out
is there a way to prime these motors?
Old Nov 22, 2010 | 06:50 PM
mud's Avatar
mud
sound air bound try pulln the line at fuel pump see if u have fuel comn out wen u crank it, pump sounds air bound ,that has mech. pump on block ,unless it was changed electric one, let me no how u make out!
Old Nov 22, 2010 | 06:54 PM
me and dad got her runiing but my brand new rebuilt trans wont shift into third gear SOB
Old Nov 22, 2010 | 07:06 PM
wildbill's Avatar
Best mod is to get a fuel pump blank, and run an electric fuel pump instead.
Old Nov 22, 2010 | 10:13 PM
Crazy's Avatar
check the plugs at trans and all the grounds
Old Nov 23, 2010 | 06:46 PM
there are no plugson trans one wire and 1 vaccum line its an 83
Old Nov 23, 2010 | 08:16 PM
mud's Avatar
mud
check all vacumes
Old Nov 29, 2010 | 08:19 PM
83cucv1028's Avatar
try a new modulator, they are pretty cheap. also check the steel vaccum line that runs from the front of the engine to the transmission, mine is all rusted shut, had to bypass it.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Dye Guardian
Aug 1, 2015 01:28 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
