Timing to 17,5°
ok, will i fry my HG ?
i took threading oil and torqued the bolts to 150...
and how the **** do i time in the pump ??
i loosened the 4 bolts holding the pump and it didn't move one bit ???
i'm really considering taking the truck to a shop to have this done and fix the KDP at the same time :P
you change the timing by the gear that runs the pump and without studs you will blow that gasket i would not go more than 16 degrees
also you have to have a timing tool to time your pump
TSB 18-10-94 Rev. A
that link will show you how to time it
TSB 18-10-94 Rev. A
quiksilver1j
Jul 30, 2015 12:41 PM
SMatyac
Nov 15, 2014 07:35 PM
