Injector pump leaking
Old Nov 22, 2010 | 11:26 AM
Levi Miller's Avatar
Default Injector pump leaking
ok guys my pump is leaking out of the top in the afc housing i took the top off and tried to pull the fuel pin out and i cant get it out it seems like its stuck in the pump so i put the top back on and it still leaks out of the side where that little ruber cap is and ideas on what to do or what is wrong anything would help thanks
Old Nov 22, 2010 | 10:54 PM
Mark Nixon's Avatar
The 'O' ring on the fuel pin is leaking.
This 'O' ring is located behind a hex-headed cap, just behind the throttle assembly, but in order to access the pin, the afc lever must first come out.
You need to remove the complete top, NOT the diaphragm cover, but the top itself.
In order to do that, you need to remove the throttle lever assembly, the reurn line, the fuel screw and take out the 4 larger allen head cap screws.
Once the top is removed, the afc LEVER pin needs to come out, there are 2 steel ***** over this lever pin.
You must drive one out by knocking the other into the afc lever pin, then once the 1 ball is out, you then drive the afc lever pin back into the other ball to remove it.
The afc lever pin can then be removed to extract the afc lever.
Now, the large allen headed screw, right behind where the throttle shaft was protruding through, needs to be removed.
Under that is the 'O' ring, BUT it is retained with a small hollow screw that has a hex center, which also needs to be removed.
After that is out, use an angled pick to extract the old 'O' ring.
As complicated as it may sound, once you have done one, it is not nearly as hard as it would seem.
Mark.
Old Nov 23, 2010 | 11:08 AM
ok thanks man will do
|WYG|SS
Apr 28, 2015 03:59 PM
bryan0702
Mar 18, 2015 05:03 PM
dieselpowa
Feb 7, 2015 10:07 PM
Stox5225
Nov 18, 2014 01:04 PM
WickedEvo
Oct 20, 2014 10:50 PM
