Banjo Bolt on a 2007 Cummins fuel canister intake line.
Old Nov 22, 2010 | 10:06 AM
mr_GDR's Avatar
Default Banjo Bolt on a 2007 Cummins fuel canister intake line.
I came here to find out the answer to this question: What is the size is the Banjo Bolt on a 2007 Cummins fuel canister intake line.
I seen some answers but they are not all the same...there should be one that is right.
my truck is stock and I want to add a fuel pressure gauge to it.
I would like to just go down town and pick up a adapter to do this, but not even my Dodge dealer knows what size it would be ...
so here it is...
what is the size?
where on the net could I get what I need?
and is a fuel pressure needed on the 2007?
I have put some info on YouTube on after market gauge's if any one needs any help.
it would be found under MrRatmandu.
Old Nov 22, 2010 | 10:19 AM
Red_Rattler's Avatar
High Tech Redneck
MOVED...! Please find the right area for questions...
Old Nov 22, 2010 | 10:22 AM
High Tech Redneck
Also, just take the banjo bolt and drill and tap it and put the sender in. Free and simple. Also my truck had around 12-15 stock at idle. Also I'd go after the filter to show you when it is getting dirty (restricting flow)
Old Nov 22, 2010 | 11:18 AM
Yes, you want to put it after the filter. Remember, you will be working on the clean side of the filter and you can very easily get crap in your pump if you arent careful.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
