12v mods
Old Nov 22, 2010 | 03:13 AM
jd18's Avatar
cool 12v mods
im justin guys and i just got my first 12v as my project and i am wanting some ideas on performance upgrades that i should do.
I would like to start off small them keep going.
any help is appreciated
justin
Old Nov 22, 2010 | 05:57 AM
monster12valve's Avatar
i would start by reading the stickeys at the top of the section about afc tuning and free mods.
Old Nov 22, 2010 | 09:07 AM
5.9Bronco...eventually's Avatar
at the same time you should also put in the usual gauges. EGT, boost, if you have an automatic a tranny temp gauge. Then look at upgrading the tranny
Old Nov 22, 2010 | 11:55 AM
BRE's Avatar
BRE
You have just opened a huge box of things to do. You will eat and sleep cummins from this point on. However gauges should be a first, along the same lines of getting air in and out of the motor, I personally would suggest if the truck has any amount of miles on it running the valves first checking it over making sure nothing needs taken care of in the first place before the mods take place. Another big one that is not one to be taken and pushed aside is the KDP. If it hasn been done you need to look into taking care of that first. If your truck is an auto its not going to take much if it is stock. We shall start there because i know i am forgetting the easy things and hopefully some one else will chime in on the subject. But as monster12valve said the stickies are great and you will read hours and hours of things with the search button. You might fill out your sig also so we know what your working with so maybe we can point you in the right direction.
Old Nov 22, 2010 | 12:56 PM
12vcummins96's Avatar
what power levels are you trying to achieve
Old Nov 22, 2010 | 02:02 PM
jd18's Avatar
thanks guys and i have gauges in the mail as we speak..and ill fill out my sig to help out..haha
and my truck is a 96 single bab 4x4
manual trans
299,000 miles bout to roll over 300,000
any more help appreciated guys
Old Nov 23, 2010 | 12:09 PM
BRE's Avatar
BRE
Like 12vcummins96 asked, what you plan on doing with your truck and your goals is another big question.
Old Nov 24, 2010 | 01:44 AM
jd18's Avatar
im not building my truck to a specific thing its just a project.
i want to start small and keep goin with mods so really im not looking for a specific power # just love diesel and like making power and looking good
Old Nov 27, 2010 | 10:23 PM
truckinbiker's Avatar
Now that you have gauges you should go with the standard air in air out. Go for a BHAF, and an exhaust, the biggest with the least restrictions your local laws and wallet will allow. if you need part#s for BHAFs let me know. You can mess with the star wheel and slide the fuel plate fwd, and like M12valve said you can find all kinds of threads about that. You should get a fuel plate, which one depends on what you are going to use your truck for. I wouldn't go with anything lower than a 10 if you are gonna haul and tow alot with your truck. If it's gonna be purely a play rig go for a 100 or a 0. The 100 helps keep smoke at low RPM down then lets it roll in accordance to your right foot up higher. The 0 is all about fuel right now, some guys say you should just take the plate out, then there are others who say it can run away if ya do that. Believe what ya want but personally I'd rather be down a couple horses then an engine. After that theres delivery valves, governor spring kits, turbos, injectors. One thing don't bother with the Mack plug, it's not good for the 215 pumps.
Old Nov 28, 2010 | 12:13 AM
jd18's Avatar
thansks for the help and im kinda new to diesels so could u explain to me wat a BHAF is and where i can get it and the parts #s and could u tell me where a good place to get a good plate?
