ht3b,col and hot pipe
Old Nov 22, 2010 | 12:58 AM
blazier18's Avatar
Default ht3b,col and hot pipe
i have a chance to get everything i need to hook up to my hx35 to make twin turbos for 500 dollars ht3b has no shaft play at all everything looks solid and clean. with marine 370's afc ff #0 plate ff starwheel ff fuel screw ff foot and barrel cut 1/8 inch and washers swapped. wat hp should i be lookin at truck will be manual in the next week completed with a clutch to hold up if funds are right. 5 inch turbo back cold air intake
Old Nov 22, 2010 | 05:13 PM
12vcummins96's Avatar
is really hard to say you should be around 550 to 600
Old Nov 22, 2010 | 05:24 PM
Red_Rattler's Avatar
High Tech Redneck
head studs and oring in there anywhere?
Old Nov 23, 2010 | 06:26 PM
blazier18's Avatar
ha ha not head studs im gonna set my psi at 35 so i dont blow up my little 35 and oringed head fire ringed head and done shaved the head and put the biggest gasket i could buy under it. one day im gonna flow my pump to 400cc then do delivery valves head studs at the same time........and gauges
Old Nov 24, 2010 | 08:33 AM
dan33klein's Avatar
Ok your putting in 370 MARINE injectors without an egt gauge? Your installing twin turbos with out a boost gauge? Your Gunna set your twins at 35psi when the 35 alone is capable of that? Your creating a recipe for disaster and your headed in the complete wrong way.
Old Nov 24, 2010 | 11:04 PM
blazier18's Avatar
so is runnin twins with a 35 bad idea
Old Nov 24, 2010 | 11:32 PM
turbostang7's Avatar
no, he isn't saying that, he is only saying that your hx35 is capable of your 35psi goal. and with injectors and twins, guages are a must. its fine to run them as a twin setup. you should defenetly invest in guages first so you can monitor things, and from what i understand a retorqued head gasket stock can handle closer to 50psi but not sure i would trust it too long. personaly i would get the supporting mods ie guages, headstuds, possibly o-ring/firering the head, then injectors and twins so you wont have to worry latter
Old Nov 25, 2010 | 12:52 AM
crzycummins's Avatar
agreed...get some gauges! those twins should be capable of making 50+ psi. just dont run it much over 50 without studs etc.
Old Nov 26, 2010 | 01:26 PM
dan33klein's Avatar
I'm running hx40/ht3b wastegated and BOV at 85psi
Old Nov 27, 2010 | 01:32 AM
fivepointohno's Avatar
making power is easy keeping it together is also but no one wants to spend the money if it don't make more hp
j1004ss
9
Dec 23, 2021 02:59 PM
camp9
Mar 25, 2017 07:40 AM
drsparkman
Nov 4, 2015 10:32 AM
98suburbandiesel6.5l
Jul 25, 2015 03:25 PM
Dustin M
Mar 17, 2015 08:59 PM
