cruise control
Old Nov 21, 2010 | 10:48 PM
24vcumminscowboy's Avatar
Default cruise control
hi everyone i was wandering if anyone knew what it would take to install cruise control i found the cruise control switches on ebay the only thing im unsure of is whether or not the wires are all there im sure ill have to tear apart the steering wheel to get them i know dodge wired them up for pwr windows and locks just dont know whether or not they wired in cruise i know when i start my pickup theres a cruise light above my odometer any way srry about the long thread but if anyone has info on this it would be tremendously helpful thanks for readin.
Old Nov 21, 2010 | 10:54 PM
navy_welder's Avatar
From what I've seen the wires should be there in the column under the turn sig switch and if I remember right the main wore is pink and yellow I believe but I will look in the morning and let you know
Old Nov 22, 2010 | 09:38 AM
kazairl's Avatar
Auto or manual?
Old Nov 22, 2010 | 01:16 PM
manual
Old Nov 22, 2010 | 10:47 PM
kazairl's Avatar
The buttons might be all you need. By 2001 The manuals were controlling the cruise control directly in the ECM. So you won't have to worry about vacuum solenoids or things like that.
Old Nov 22, 2010 | 11:13 PM
thanks kazairl im going to tear into the steering column over thanksgiving and find out if the wires are there
Old Nov 22, 2010 | 11:48 PM
kazairl's Avatar
Unless the clock springs are different, there should be 2 connectors that aren't used behind the air bag. Make sure you pull the fuses before you pull the air bag out. If not then you might have to buy a different clock spring.
Old Nov 26, 2010 | 10:17 AM
crazycooter's Avatar
you have to change your clock spring, and add your buttons. easy as that. make sure you let the power drain out of your system long enough to not set off your airbag. other than that, your wiring harness is ready to go because you have a manual. you don't need a servo or anything, the cruise is directly between your pcm and your vp44. I know all of this because I bought more parts than I needed to put cruise on mine...
burndiesel
10
Feb 7, 2023 01:15 AM
JBearSVT
Jul 9, 2015 06:16 PM
jdnetx
Jul 2, 2015 07:38 AM
Oil Igniter
Nov 27, 2014 05:56 PM
Cliffordthe24v
Nov 6, 2014 12:19 PM
