New Batteries Now No Start
Old Nov 21, 2010 | 06:33 PM
Bigd2000's Avatar
Default New Batteries Now No Start
Brand new to the forum and brand new to dodge. Truck is a 2006 Cummins. I replaced both batteries the other day. Truck fired right up no problems so my wife and I decide to go get a bite to eat. About a mile away from the house the truck dies and will not start back. It will turn over but will not start. The check engine light flashes when I turn the key on. I tried to check for codes but get nothing. Done the key on-off 3 times, all I get is ------- then it says "done" Any help would greatly be appreciated.
Old Nov 21, 2010 | 07:18 PM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
Check for fuel pressure coming into the cp3(injection pump) Could be a couple of things. One the lift pump, another possiblity is a locked up integrated control module( fuse box under the hood).
Old Nov 21, 2010 | 09:57 PM
Bigd2000's Avatar
Just got it figured out. The ground wire was loose going to the ecm.
Old Nov 29, 2010 | 07:30 PM
mxtuner1's Avatar
Also really clean those new terminals and cables - crazy things happen with bad grounds. Also remember most new batteries are not fully charges so hit it with a slow charger overnite. I found out it does a better job individually to charge each battery separate with the cables off.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
