head lights mess with gauges
Old Nov 21, 2010 | 10:26 AM
redwood logger's Avatar
Default head lights mess with gauges
My gauges peg and some go limp when I turn lights on is this a common problem
Old Nov 21, 2010 | 10:58 AM
RSWORDS's Avatar
Yep, your body ground from the neg post on the battery to the core support is shot. Replace it with heavier gauge wire. The bigger the better...
Old Nov 21, 2010 | 02:33 PM
blazier18's Avatar
its more than likely the voltage regulator i have a 91 first gen truck that had the same problem then it was fixed after replacing the voltage regulator located on the firewall near the windsheild wiper motor...
Old Nov 21, 2010 | 03:20 PM
chromehound's Avatar
^^^The 93s don't have a voltage regulator like that.
Best guess is the main ground is shot as was stated or if you taped into your headlights for lighting your guages that your drawing to much power and causing problems.
Old Nov 21, 2010 | 04:57 PM
Ihave not tapped into anything it has only done it twice I will check that ground
Old Nov 21, 2010 | 05:06 PM
RSWORDS's Avatar
Even if its not "bad" by looks its probably rotten inside, also they were under sized from the factory. You will be worlds ahead to just swap it out even if its not bad right now.
zach11
6.7 Liter Dodge Cummins 2013+
Aug 14, 2015 02:53 PM
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
Adam65
Jan 9, 2015 11:50 PM
bypass-21
Jan 3, 2015 04:47 PM
