stiffer valve spring disadvantages??
Old Nov 20, 2010 | 08:05 PM
RamblinWreck's Avatar
Default stiffer valve spring disadvantages??
Are there any disadvantages to putting stiffer springs in for a higher redline?
Maybe the cost of doing it, lower MPG because the engine has to work harder, higher idle speed because it may idle rougher??
Old Nov 20, 2010 | 08:09 PM
You already have 60 pound valve springs. Wondering what your talking about.
Idle speed is controlled by the ecu.
Old Nov 20, 2010 | 09:09 PM
Thank you, I'm just getting started with bombing and would like to learn the advantages & disadvanges of each mod before doing. I also don't see much discussion of the disadvantages of a mod in the forums.
I'm interested in increasing the top speed of the engine and read that sitffer springs will prevent valve float. Are you saying that 60 pound springs are the stiffest I can get for this engine? If stiffer springs are available what are the disadvantages of using them?
Sounds like an ECU update is necessary to increase top engine speed.
Old Nov 20, 2010 | 10:59 PM
There probably are better quality springs available. Most people upgrading valve springs are doing so in 12V engines. The 24V stockers are beyond fine for most people.
To make power on a diesel you need to add fuel (fueling box, SMARTY tuner, and/or injectors), and get a free flowing air filter, and get a 4 or 5" exhaust.
After that, a turbo upgrade is necessary.
Of course, before you start this, you need to have guages and a transmission upgrade (clutch for a stick - full meal deal ($$) if you have an auto)
I am not sure when the engine defuels but I believe you can take care of that with a tuner.
Old Nov 21, 2010 | 11:04 AM
01quadcab's Avatar
I have 110# valve springs in mine this was done for higher boost and pressure associated with compounds.
Old Nov 22, 2010 | 09:50 AM
connermcpherson's Avatar
i got #110 coming, my pump swap will be turning 4200
Old Nov 22, 2010 | 10:05 AM
Thank you, are there disadvantages to using the 110# springs? And are the 110# springs primarily for higher boost/compound turbos? Are they necessary for higher engine RPM?
Dr. Evil, thank you. I think your basic upgrade list should be a sticky thread. EJWA & monitor is at the top of my list.
Old Feb 19, 2011 | 05:04 PM
RAW's Avatar
RAW
I would say so. The valves are cycling much faster, and could use the extra help to slam shut.
Probably a unmeasurable increase in rolling drag. Might pull a few extra amps to start the engine......maybe.
51Hudson
55
Jul 8, 2018 08:17 AM
RA113024
Mar 13, 2016 07:42 PM
markv8993
Jun 21, 2015 12:24 AM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
