axle ratio question
Old Nov 20, 2010 | 10:02 AM
DanLowe's Avatar
Default axle ratio question
Someone started a gear ratio swap thread and it jogged my memory...the truck in my thread has a Dana 80 rear end, my glove box says 3.55, but the tag on the axle says 3.54...any answer as to why this is? Anybody else have this with their truck?
This is one answer I got...
to answer you question about your gears. the front has one different than front. like 3.55 and 3.54 and 4.10 and 4.11 . this is done because the front is turning. it keeps the 4 wheel drive from binding up as bad. when i was a kid jeeps had the same front and back ratio and they would bind up and was dangerous on snow highways at speeds. its like not having the same size tires on it. hope i got my point across. thanks ****
Old Nov 20, 2010 | 10:49 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
you will find one end is 3.55 and the other is 3.54
Old Nov 20, 2010 | 11:25 AM
mxtuner1's Avatar
also with different amount of teeth on gears (both large and small gears) it is nearly impossible to get the exact same ratio
Old Nov 23, 2010 | 01:19 PM
KATOOM's Avatar
Right. And this is because the front and rear axles dont spin at EXACTLY the same speed. Not enough to notice unless you run on dry pavement.
Old Nov 23, 2010 | 02:58 PM
diesel pap's Avatar
the old jeeps were the same ratio and dangerous on the snow covered highway.
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Dec 19, 2014 02:30 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
natenel1
Oct 26, 2014 03:09 AM
94cummins12v
Towing and Hauling
Oct 21, 2014 02:50 AM
