Just died after acceleration
Old Nov 19, 2010 | 09:13 PM
blowin smoke 1's Avatar
Sad Just died after acceleration
My truck just shut off with the quad in 7 took off hit third let off and it died I finally started it up with some starting fluid.Do I need to put the spring in my airdog?It has never did this before?
Old Nov 20, 2010 | 09:59 AM
mainman300's Avatar
mine would do this as well, not all the time but seemed to happen when the fuel was warm under WOT, Came to the conclusion that it was my fuel shut off in my vp was closing so fast that my engine kept pulling fuel and caused an air gap. Try replacing your over flow valve as well there cheap.
Old Nov 20, 2010 | 01:51 PM
mishkaya's Avatar
Used to happen to me relatively frequently. I take it you probably are not running the most current tunes from Quad? I thought they had solved this problem. I know I haven't had the issue again since upgrading to the V2 Adrenaline. You didn't need starting fluid BTW, all you needed was to bleed the injector lines and it would have started right back up!
Old Nov 21, 2010 | 12:09 AM
I have the v2 and by the way I was on an on ramp with no tools.
Old Nov 21, 2010 | 07:22 PM
crzycummins's Avatar
sounds like you starved the pump?
Old Nov 21, 2010 | 08:35 PM
My vp is 3 months old yall think I need to call quad?
Old Nov 21, 2010 | 09:07 PM
turbostang7's Avatar
i would tend to think that your lift pump isn't keeping up. whats the fuel pressure at idle and at WOT? i would start there. i had this problem once. upgraded the lift pump again and havn't had the issue again.
Old Nov 22, 2010 | 06:50 PM
My fuel press. at idle 25. wot in #10 on quad 18 psi?
Old Nov 22, 2010 | 08:24 PM
well the presure seems fine, a lil high on the idle though. maybe try a different tune on your quad.
taweste
Aug 29, 2015 02:34 PM
moose2j
Jun 21, 2015 12:36 AM
RayRay4991
Feb 23, 2015 07:45 AM
OBSBEN
Dec 31, 2014 11:35 AM
UC Kid
Oct 20, 2014 10:06 AM
