how do you stack chips?
Old Nov 19, 2010 | 08:05 PM
cummins army's Avatar
Default how do you stack chips?
ok i have been doing alot of debating and research and i didnt want to be a dumb a** but i have to be i am looking at stacking my jwa with an edge ez or ts mp8 but how would i hook the secound one up with to the map sensor if the jwa is already pluged into it thanks for the help i just am so confused on this
Old Nov 19, 2010 | 08:09 PM
crzycummins's Avatar
you would stack something like an ejwa and a smarty. something that plugs into the obd port in the cab but make sure they are compatable
Old Nov 19, 2010 | 08:14 PM
mysterync's Avatar
In all reality in most cases more power can be made without stacking. Somthing Like a smarty would provide all the power you would ever need if the truck is built properly.
Look at it like this, You can increase pressure and increase power, but you could also use bigger injectors to increase flow without increasing pressure and get more power gains. If you ask me stacking is building power, it's changing more maps to reach the desired effect, Why not go ahead and upgrade the turbo and but some bigger sticks in it and get more Good results with far less bad results!
Old Nov 19, 2010 | 08:59 PM
ok i get what you both are sayin but i just want to know how its done i read about it on here way to much and want to know if i ever wanted to try it how to go about it
Old Nov 19, 2010 | 09:34 PM
99stackedpowerstroke's Avatar
so how would you go about ta find out if there compatable???
Old Nov 19, 2010 | 10:28 PM
RAW's Avatar
RAW
I seen this on this site a while back:
Old Nov 19, 2010 | 11:09 PM
haha and my chips not on there!!! haha
Old Nov 20, 2010 | 07:31 AM
RAW's Avatar
RAW
Probably because these are for Dodges, as this is a Dodge thread.
Old Nov 20, 2010 | 08:04 AM
you would get a ejwa or quadzilla adr and get them all hooked up. then you would take your handheld, plug it in and tune accordingly
Old Nov 20, 2010 | 08:10 AM
RAW's Avatar
RAW
Just like posted above, one chip would put hotter software into your ECM. The other will all power externally, like a wire tap into your VP44. The ECU will will ask for so much, the fuel box will increase it again.
