O-Rings, Pictures, Myths, Facts and Info!
Old Nov 19, 2010 | 04:34 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
Default O-Rings, Pictures, Myths, Facts and Info!
Just figured i would post a thread that could easily be found for people searching for info and pics about O-ringing their heads...
First some facts and fiction;
  • An O-ring does not have to be installed in the engine block
  • An o-ring does not need to have a grove cut in head AND block
  • An O-ring can be glued or more correctly pressed into the grove in the head
  • An O-ring is nothing more then a piece of wire put into a groove on the head that gives extra clamping force directly on the fire ring of the head gasket.
  • An O-ring protrudes past the heads surface to establish the clamping force.
  • O-rings require many heat cycles to clamp the head down to proper torque
  • O-ring wire is cut and filed down for a tight fit in the head
  • The gap on an O-ring should be near a head bolt to help keep it tight.
Here are pictures of my O-ring job done by Advanced Sleeve in Mentor, Ohio.
450$ Later (Machining, Cleaning, O-ringing)...
400$ Head Studs, You should NOT use head bolts with O-rings...
Any questions? Just ask!
Old Nov 19, 2010 | 04:39 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
Old Nov 19, 2010 | 04:57 PM
crzycummins's Avatar
good info
Old Nov 19, 2010 | 06:45 PM
dieselboy88's Avatar
does that just help the headgasket from blowin out at higher boost and higher compression? pardon my ignorance.
Old Nov 19, 2010 | 11:09 PM
LORDDiESEL's Avatar
great info!
Old Nov 20, 2010 | 12:29 AM
Yes, in combination with head studs the rings help seal up things to over 75psi. I stretched my stock bolts and poopped the head gasket @ 35psi (and smill high boost spikes to 40psi) with the stock turbo. I ordered 130hp injectors and will probably have twins in spring. So it will need to hold strong.
Old Nov 20, 2010 | 11:43 AM
jake 94's Avatar
Can any machine shop do this and usually if I take it some place how much would it run me cash wise?
Old Nov 20, 2010 | 12:04 PM
No its not some thing that every shop does. I had to call around some. Its very precise work. I am not sure what most places charge but for cleaning, resurface head and o-ring it was 450$. I will dig up my reciept and give a breakdown.
Old Jan 25, 2011 | 10:31 AM
asmxb24's Avatar
When is it necessary to do O rings? I am planning on running small twins with a hx35 over ht3b and was wondering if you thought i would need to o ring or i can just get away with a better gasket and ARP head studs?
Old Jan 25, 2011 | 12:25 PM
arobertson's Avatar
so they dont cut grooves in the head ether? they just glue the wire on or they only cut grooves in the head and not the block?
