Lift pump help
Old Nov 18, 2010 | 08:31 PM
pipelayer4777's Avatar
Default Lift pump help
I am going to put a new aftermarket lift pump on and I'm having a hard time finding a good aftermarket. I just want a little more gph (I don't even know what stock is) at about 6 psi. I'm going to ad the Heath towing chip and turbo master so I want to make sure that the fuel is there for me. My truck weighs 14,000 lbs and makes me my money so I can't have it breakin on me. any suggestions as to where and who's product to use. I don't mind having to do some plumbing if need be. I don't really want to spend the $110 that Heath is charging for their lift pump. If I have to I will. Thanks guys. The truck already has the exhaust and intake. I'm adding all the gauges over the weekend.
Old Nov 18, 2010 | 08:51 PM
mud's Avatar
mud
thats all 6.5 can handle stock
Old Nov 18, 2010 | 10:13 PM
Crazy's Avatar
if you want put new LP in go with 93 LP IT better pump with little more psi you just wasting money if you go with hi psi pump cause IP only going put so much to the injectors
Old Nov 19, 2010 | 05:53 PM
Mud I don't quite understand your reply, And crazy I'm not worried about pressure I will not go more than 6psi max, I'm looking for a slight bit more volume. Thanks guys I know that there is not alot of aftermarket parts for these engines.
Old Nov 19, 2010 | 10:44 PM
Crazy's Avatar
there lot lot out for after market
93 will gave little more psi on LP
don't know way looking for more IP is only going let so much fuel throught you can have Lp pump putting out 50 psi but IP only going take in 5or 6 psi
Old Nov 20, 2010 | 10:54 AM
Woody35's Avatar
if you go over 14 psi you will damage the ip. 10 psi is a good number to be at. at wot it should dip down to 5-6 psi/ for a cheaper alternative you can also just wire in another stock lp inline with the other one
Old Nov 23, 2010 | 10:40 PM
Crazy's Avatar
aaa911 i would start new tread about your steering system
Old Nov 23, 2010 | 11:09 PM
DuramaxDiesel02's Avatar
Default Re: Lift pump help
He's spamming just look at all his posts. Its for his site
Sent from my Droid
Old Nov 23, 2010 | 11:19 PM
Crazy's Avatar
seeing that now
Just someone that don't know how pull his head out his a$$
Old Nov 23, 2010 | 11:26 PM
Crazy's Avatar
here kiss this
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
