Biggest tires i can use?
Old Nov 18, 2010 | 05:52 PM
Jamen89's Avatar
Default Biggest tires i can use?
What are the biggest size tires i can use on stock rims?
Old Nov 18, 2010 | 05:58 PM
CowboyDiesel's Avatar
What size lift do you got you can clear 35s with a leveling kit.
Old Nov 18, 2010 | 06:03 PM
Jamen89's Avatar
It has a leveling kit on itand will they rub?
Old Nov 18, 2010 | 06:08 PM
They shouldn't as long as you dont go with a wide tire
Old Nov 18, 2010 | 06:13 PM
Jamen89's Avatar
Thanks cowboy
Old Nov 18, 2010 | 06:15 PM
Originally Posted by Jamen89
Thanks cowboy
Slap some 35s on there it will look really nice
Old Nov 19, 2010 | 10:02 AM
Cowboy Cadillac's Avatar
Currently running BFG 37x12.50x17 on my 06 with a 2" kit to level out the front. No Rubbing so far. I have not had this thing at an angle that it rubs anyway. MPG's not great (13-15 mpg Mixed). Next set will be 35's though. This should make it a little easier to hook up to the Goose neck.
Old Nov 19, 2010 | 11:37 AM
MUDSTROKIN''s Avatar
Old Nov 20, 2010 | 06:57 PM
WhistlinDixie's Avatar
I ran 37x12.50r18 with my readylift level kit. They rubbed a little in the center of the wheel well. Also ran 325/65r18 with no rubbing
Old Nov 21, 2010 | 02:40 PM
Mdub707's Avatar
The most important part of this is the width and backspacing of the wheels. My buddy ran 37x12.5x17's on 17x9 pro-comps with a 4" lift with a leveling kit on top of that and they rubbed the inner fender wells.
It will also make a difference if you have a 250 or 350.
