Quadzilla Adrenaline questions
Old Nov 18, 2010 | 12:29 PM
cumminspowrd's Avatar
Default Quadzilla Adrenaline questions
I put quadzilla in my truck a few weeks ago and it almost instantly threw up the check engine light. i grabbed a code reader and its kicking up 4 codes for overboosting and my injector pump circuits i cleared the codes and it stayed off untill i got into the throttle alittle bit any ideas why is would happen? or should i not worry about it.... i was also told that the 4k model of Adrenaline sometimes does this but it doesnt sound right
Old Nov 18, 2010 | 12:58 PM
What were the codes? Need the numbers...
Old Nov 18, 2010 | 02:49 PM
01ISX's Avatar
Wow thats crazy man keep us posted on it Cause i was thinking about getting it for my truck !
Old Nov 18, 2010 | 07:01 PM
blowin smoke 1's Avatar
I have one on my truck and its great I took edge with juice off and installed it I will never buy edge again just my 2 cents.
Old Nov 18, 2010 | 07:51 PM
the codes are P0238, P0253, P0251 and P0252
Old Nov 19, 2010 | 07:53 AM
DanLowe's Avatar
Love my Adrenaline...had it 5 months now. No problems
Old Nov 19, 2010 | 04:02 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
Did you check to make sure that you have all the plugs in the correct spot? I have had mine on my truck and I never had a problem... Well, until i ran 3000 series tunes on it and stretched out my head bolts!
Over 35psi is not so good with the stock turbo!
Old Nov 19, 2010 | 07:58 PM
99cummins3500's Avatar
Had my quadzilla about a year. never had any trouble with the check engine light. i love my adrenaline. although my boost guage on my monitor did quit working it showed runnin 52lbs boost crusing.
Old Nov 19, 2010 | 08:24 PM
turbostang7's Avatar
i would check all the plugs make sure they are in right and tight, also the pump tap wire too. make sure its on the right wire and a good connection. i've had my adrenaline for a year now only one problem last winter when it kinda fried in the cold , but they were quick to fix it for me.
KatiTrimmell
Jun 13, 2016 12:29 PM
dodge1998
Jun 13, 2016 12:25 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
MAC4232
Oct 16, 2014 04:22 PM
