What Exactly Will Break In My Stock Auto Tranny If I Up The Power On My Truck
Old Mar 23, 2007 | 07:54 PM
RSWORDS's Avatar
Default What Exactly Will Break In My Stock Auto Tranny If I Up The Power On My Truck
Now that your in here lets get technical. I know the basics of why the tranny will take a crap. But Lets use this thread to discuss exactly what goes wrong inside when you "bomb" the truck in detail. Lets talk about what the Torque managment System does and why it is critical to a stock tranny. Lets Discuss the popular upgrades for a tranny with more than "A new torque converter and valve body with make it work"... WHY WILL THEY MAKE THE TRANNY BETTER!?!?!? Anyone can quote those answers... Lets here some theories.
I think this has the chance of becoming a very useful "Tech" artice for new guys. I know it took me a good night of searcing when I bought my CTD last week to get al the info I wanted. And I still have some questions. I like to know why something broke and why a fix works, not just that it does.
Thanks Guys!
Bobby
Old Mar 23, 2007 | 08:21 PM
Diesel Dummy's Avatar
A heavy right foot!
Old Mar 24, 2007 | 11:47 AM
Benjamin's Avatar
Bombardier
the converter is to me the weakest link..... let me quote Dave Goerend from www.Goerend.com....
Originally Posted by Dave Goerend
For a standard duty application we like to start with a low stall triple disc converter that will keep the engine in its torque range of about 1700-2200 rpm. Put another way, the upgraded converter will have the engine working at about 500-800 rpm lower than a stock converter. The stock converter usually lets the engine rev to 2300-2800 rpm, which is past its peak power rpm. On a 24 valve Cummins Turbo Diesel with the "Common Rail" system this torque range will be slightly higher.
In order to understand the benefits of this upgrade it is important to know how a torque converter works:
Torque Converter Basics
Let’s start with 2 wall fans facing each other:
If we turn one fan on the wind from this fan will make the other fan turn, although much slower than the "drive" fan. In the case of a torque converter, the drive fan is bolted to the engine and the fan being driven is connected to the input shaft of the transmission. In addition a oil is used to transmit the energy between the two fans, as opposed to air in the example scenario.
When stationary (such as at a stop sign), with the trans in gear and the engine at idle, the drive fan is spinning so slow that it will not "blow" enough oil at the driven fan to make it turn. As the engine speed is increased the drive fan blows more oil at the driven fan and the driven fan starts to turn and moves the vehicle.
This important concept is commonly referred to as "fluid coupling".
The drive fan will always turn a little faster than the driven fan, just like the wall fans. If you were to stick a feather, or straw, into the driven fan blades it would slow the driven fan down but not the drive fan. In a real application this is just like pulling a heavier trailer, the straw in the driven fan is essentially adding a load.
Torque Converter Lock-up
Once the truck is up to speed there is a mechanism, called a lock up clutch, that will "lock" the fans together. In actuality the driven fan is "locked" to the front cover of the torque converter, which is bolted to the engine. When this occurs the drive fan and driven fan turn at the same rpm, with no loss of power in the fluid coupling.
When the drive and driven fan are not locked together, heat is generated in the converter. The greater the load and rpm difference, the greater the heat generated. This heat is essentially lost power which results in a lower transmission life, performance and fuel economy.
The loss of energy in this process can be calculated: suppose we have a converter where the drive fan (impeller) is turning 2500 rpm and the driven fan (turbine) is turning 1800 rpm. The efficiency of this converter, at this speed, is 72% (1800 divided by 2500). The efficiency is constantly varying, depending on the rpm of the converter, the power input to the converter and the output load, or towed weight. When the converter clutch locks the fans together, the engine rpm will drop 700 rpm.
If we use a converter that is more efficient, such as a "low stall" converter we will be able to achieve a higher efficiency rate. For example, an 88%, efficiency rate would mean that the impeller would be turning 2500 rpm and the turbine would be turning 2200 rpm. When the converter clutch locks the turbine to the front cover we would only see a rpm drop of 300 rpm, as opposed to 700 rpm.
A lower rpm drop is substantially easier on the converter’s clutch lining and will reduce glazing. In addition, because the fluid coupling of the converter is more efficient, more power, less heat and better fuel economy are delivered before the converter locks up.
Torque Converter Stall Speeds
To explain "stall speed", let’s start with a true full stall. If the transmission were in drive, the brakes were held down (so the vehicle will not move) and the throttle was held "wide open" the torque converter will "stall" the engine at a certain rpm. When "stalled" the engine will not be able to spin any faster unless the vehicle is allowed to move. This is a true full stall. We have specialized equipment which is used to perform this test.
DO NOT TEST FOR TRUE STALL, IT CAN DAMAGE SHAFTS AND OVERHEAT THE TORQUE CONVERTER!
The next stall speed is generally called "break away" stall speed. If a truck is stopped on a hill and held in position using light throttle as opposed to brakes we are almost at the "break away" stall speed. If the engine rpm required to "hold" the truck was 1100 rpm and an increase to 1125 rpm started to move the truck then the "break away" stall speed is 1125 rpm.
The last stall speed is generally referred to as the "flash stall" speed. The flash stall speed takes effect under hard acceleration. If, from a standing start, you were to "floor" the throttle the engine would start to accelerate quickly and then pause at an rpm is it starts to pull the truck. If the engine went from idle to 1500 rpm in 1.5 seconds when floored and then took another 2 or 3 seconds to get from 1500 to 1700 rpm, this would mean the "flash stall" speed was at 1500 rpm. When we lower the stall we want to lower the break away speed as well as the flash stall speed. This will make the engine work at a lower rpm for a given road speed and, in most cases, will increase fuel mileage.
Once up to speed, the computer will command the lock up clutch "on", and the driven fan will lock to the front cover of the converter. At this point the drive, driven fan and engine are turning the same speed which means all engine power will be delivered to the transmission and back to the wheels.
Upgrading Your Stock Converter
In a stock torque converter, the clutch has 1 clutch plate with about 37 square inches of clutch lining. At Goerend Transmission we like to use 3 clutch surfaces that total about 105 square inches of lining, we call this a triple disc converter. This triple disc will hold dramatically more torque than a single disc.
Old Mar 24, 2007 | 11:55 AM
Johnny Cetane's Avatar
and that concludes our lesson on torque converters today, children. hard to add to that.
valve body upgrades are important for a few reasons. added "clamping" power for the new converter you've just installed being one. plus modifying shift points. in general increased line pressure to get clutches mashed together.
the ya got the weak input shafts that'll crack under stock power levels let alone with upped power. switching these to billet is a good idea.
Old Mar 24, 2007 | 03:27 PM
RSWORDS's Avatar
That Quote is great.. Never seen it before.
Old Mar 24, 2007 | 04:06 PM
Dr.Automotive's Avatar
BANNED CROOK
Only thing left, if it wasn't in the replys already, is an increase in the leverage ratio to the band and the added benefits of better lining materials. A properly timed shift with the correct pressures. The ability to lock the converter on command is also a nice feature.
Old Mar 25, 2007 | 10:19 AM
RSWORDS's Avatar
If you make it so you can lock the Torque Converter up on demand (via a switch) caan you run a chance of not knowing what you are doing and screw it up? Maybe lock it to soon or to late?
Old Mar 25, 2007 | 11:38 AM
cerberus60's Avatar
Specifically, break input/intermediate shafts if your not careful, and, slip the TC clutch if the pressures are too low for the power level.
wannadrag
May 25, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
