6.2l question about breather hoses
Old Nov 17, 2010 | 08:35 PM
92typhoon937's Avatar
Default 6.2l question about breather hoses
there are two hoses that go into my intake one on each side that comefrom a hose on the fill tube can i just plug of them and get rid of them so it dont suck the oil into the intake casue it was coated on the inside when i took it off
Old Nov 18, 2010 | 09:49 AM
mud's Avatar
mud
I wouldnt oil will just find another way out could cause bigger problems. need to find out y u getn blowby.
Old Nov 18, 2010 | 12:01 PM
Livelli's Avatar
Yeah, I wouldn't go messing around with those hoses. They provide a small amount of vacuum to the crankcase to limit oil leaks. If you have a bunch of oily slime you'll need to either replace or clean your CDR valve (tuna can on the front pass side of motor). To clean it, just take it off and wash it out with either diesel fuel or gasoline, then let it dry. Repeat the process a few times til the "solvent" comes out clean. If the diaphragm inside is bad, you'll need a new one. If so, let me know and I'll find a part number and maybe a CDR in your area.
Old Nov 20, 2010 | 11:43 AM
thank you will pull it off and clean it out and look it over
Old Nov 20, 2010 | 11:13 PM
Crazy's Avatar
X2 what Livelli Said
RatsMC
May 4, 2015 05:25 PM
JPT18
Mar 11, 2015 04:25 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
