2wd to 4wd
Old Nov 17, 2010 | 03:05 PM
dieselbomb87's Avatar
Default 2wd to 4wd
I have an 06 mega cab 5.9 cummins. Its a 2wd what would it cost and how much would it take to make it a 4wd?
Old Nov 17, 2010 | 06:32 PM
830cummins410's Avatar
not to much ust go trade it in! sounds like to big a project to me everthing would have to be perfect
Old Nov 17, 2010 | 08:14 PM
torqctd's Avatar
Trade it in on a 4X4......a lot of work, headache, and expense..........trust me.......even on a simple 70 GMC.
Old Nov 18, 2010 | 01:39 PM
KingCopa's Avatar
You would need front axle, all front suspension, transfer case, drive shaft,s interior parts like floor consoles and then you gotta hack you old suspension and mounts off and fab all new stuff. Way to much work if you ask me unless you have the skills necessary to do it and can afford the down time on the truck. Plus I'm sure just factory parts will be in the several thousand dollar range for just the axle and transfer case. Would be nice to see a write up on it if you do tackle it though
Old Nov 19, 2010 | 02:37 PM
goodolboy's Avatar
pretty much go to a junk yard cut the a frame build a jig and weld it back on but you better be damn good with a welder
Old Dec 11, 2010 | 03:32 AM
Cumminpwr11's Avatar
I did this on my ole 99.
axle $350
divorced NP205 $250 (foor mount cable shift)
Rebuild kit for NP205 $145 (was just in case)
drive shaft $200
Deaver front and rear 8" mini pack lift leaf springs $3400
and what ever you charge yourself for labor $$$$$ mine labor was free
With my buddies helping it took two full beer drinking weekends. and never a problem with it.
under 5K is a lot cheaper than a new truck
twinboys
Feb 18, 2015 06:55 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
mw1095mw
Jan 4, 2015 11:06 PM
Machinist
Dec 5, 2014 01:06 AM
Resolute_Welding
94-98 7.3L Performance
Oct 21, 2014 08:22 AM
