Trani swaps
Old Nov 17, 2010 | 09:48 AM
Billy D's Avatar
Default Trani swaps
If and when I need a trani, should I get one with an overdrive that should get me one mo MPG shouldn't it or should I stick with my 727
Old Nov 17, 2010 | 02:24 PM
Vargafarm's Avatar
I used to want to do a swap, but a good rebuild of the stock tranny and a better torque converter seems to be the right answer for me.
Course a good donor truck sitting beside it might make me change my mind.
Old Nov 18, 2010 | 09:22 AM
kcwell27's Avatar
Make sure you pull the gear shifter to 1st gear when starting out with a heavy load. At least thats what I have heard AFTER I trashed TWO 727s Now I'm rolling with a Turbo 400
Old Nov 18, 2010 | 11:15 PM
fumminsplease's Avatar
eww turbo 400 thats just wrong
Old Nov 19, 2010 | 07:40 AM
kcwell27's Avatar
Default Wrong?
Wrong is blowing the sprag out of the case. Then installing a bolt in sprag like you would use in a drag car and blowing it out too. And this truck only has a little pump work! I can get stupid with a turbo 400! Now I can run any Turbo 400 chevy, BPO
Nov 28, 2014 09:50 PM
