what 3 Gauges to go with
Old Nov 16, 2010 | 08:12 PM
Jamen89's Avatar
Default what 3 Gauges to go with
So would the pyro,fuel pressure, and bost be good or pyro,boost, and trans????
Old Nov 16, 2010 | 08:29 PM
billsee1982's Avatar
I think it all has to do with what you do the most, if you do a lot of towing and have an after fuel system i would go with pry, fuel and trans temp, if you do alot of racing fuel boost and pry, or if its just a daily driver that you tow with when you need to and running the stock pan i would go with boost trans ant pry.
Old Nov 16, 2010 | 08:38 PM
Mdub707's Avatar
I'd get fuel pressure (#1 most important gauge on any 6.0), then engine oil temp and engine coolant temp. Montioring both of these temps simultaneously is very important so you can see when the oil cooler is becoming clogged, this leads to headgasket failure and egr cooler failure. If you're running a programmer a pyro would be next. A tranny temp gauge is really only necessary if you're towing heavy all the time. I tow a 5k lb camper during the summer through the adirondacks and I've never had my trans break 170 degrees. If you tow heavy and often though, probalby a good idea.
Old Nov 16, 2010 | 08:57 PM
WhistlinDixie's Avatar
Pyro is important on all diesels.
Fuel Pressure to make sure you dont starve the injectors.
Comparing Oil temp and Coolant Temp will tell you if your oil cooler is still good.
Im doing a write up on my gauge install. Its a simple process but Im trying to do one on every mod i make to my truck. Im just waiting on the adapters to come in.
Old Nov 30, 2010 | 07:42 PM
ranger518's Avatar
fuel pressure, coolant temp, and oil temp. and pyro if running tunes
flainn
Oct 12, 2024 09:39 AM
Powerstroke36
Sep 6, 2015 02:41 PM
May 1, 2015 08:10 AM
Justin82
Price Quote - Request A Price
Apr 1, 2015 02:22 PM
carid
Diesel Bombers Sponsors
Dec 9, 2014 03:58 AM
