Throttle goes dead.
Old Nov 16, 2010 | 11:45 AM
utarcher123's Avatar
Default Throttle goes dead.
The reason Im switching to a new chip is because, I can be cruising along. Then all of a sudden my throttle goes dead. I can floor it and nothing changes. By letting it on/off a couple of times BOOM there it goes. It started a while after putting the Work Horse Power Module on it It will go for days/weeks then it'll do it again.Took the module off. And now it only occasionally does it. And not as bad.
Know what it is?
Thanks.
Mike
Old Nov 16, 2010 | 11:46 AM
Sounds like your VP44. Got any codes?
Old Nov 16, 2010 | 11:58 AM
No. How do I get em? Does it sound like bad codes,....or bad pump?
Old Nov 16, 2010 | 12:10 PM
01ctd's Avatar
friend of mine just purchased a 2002 3500 quad with only 73,000 miles, same dead pedal. Had the lift pump tested with ZERO pressure. No Codes.... have your pressure tested before it's too late.
Old Nov 16, 2010 | 12:16 PM
1stgenman's Avatar
I goot a buddy that just had the same problems and we had to put a new pump n his so I would get your pump tested before you start going into other issues like the Throttle position sensor or something of that cause
Old Nov 16, 2010 | 12:42 PM
moparious maximus's Avatar
Dead pedal says to me the vp-44 is done, if its just a lift pump you lucked out bigtime.
Old Nov 16, 2010 | 01:37 PM
crzycummins's Avatar
i would bet you get the infamous p0216 code...get a scanner and check for any or take it somewhere and have it scanned. also get a fuel pressure gauge if you dont have one!
Old Jul 11, 2012 | 11:02 AM
thefoolishfarmer's Avatar
so if you get the 216 code.....then what does it mean????
Old Jul 11, 2012 | 11:06 AM
Farmboy 2.0's Avatar
Generally, The 216 code means the pump is dieing
Old Jul 11, 2012 | 12:14 PM
RollinCoal99's Avatar
if your VP is done and your lift pump is stock in tank pump you might as well buy a Vp and air dog or Fass package deal so you can kill 2 birds with one stone
burndiesel
10
Feb 7, 2023 01:15 AM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
Daylon
Aug 22, 2015 02:04 PM
1stgenswap
Nov 3, 2014 09:45 PM
