what percedures on changing injector on 6.0
Old Nov 15, 2010 | 08:38 PM
redroadrunner27958's Avatar
ATTN what percedures on changing injector on 6.0
Im not getting good fuel mileage.one minute is 18 to 19 then later im getting 13.when I first start up she blowing white smoke and I let it warm up then it run fine.I have changed my EGR,FUEL PUMP,FUEL CONTROL MOD.I would like to know what it takes to break down and change my injectors just in case I ever have to do it.any way can someone help me with these problems
Old Nov 15, 2010 | 09:45 PM
Mdub707's Avatar
You should get the truck properly diagnosed before throwing more parts at it. White smoke is usually coolant burning (or just moisture in the morning), but sometimes it can be fuel on these. When it's blowing white smoke try and smell it. See if it's sweet and easy like coolant or if it burns your eyes like diesel. When you say EGR, did you replace the valve, the cooler or both? Why was the fuel pump changed? Why was the FICM changed (fuel injector control module, it's what I'm assuming you're talking about when you say Fuel control mod). FWIW, 18-19 is awesome mileage. I typically see between 13-15 in my extended cab shortbox 4x4 auto with tuner.
What are you using your truck for, and how many miles are on it? When's the last time the oil and oil filter was changed? What kind of oil? When's the last time the fuel filters were changed?
I wouldn't be too worried with injectors just yet, or at least I'm leaving that alone until we have more info.
Welcome to the board!
Old Nov 16, 2010 | 08:30 AM
I change my oil/filter on a regular base.as far as the smoke it smells like fuel.I had a problem not starting and cared to dealer.They changed fuel pump,EGR and the fuel control mod.most of the time im only getting 13 to 15 mpg.I have a friend that has the same truck and he is getting 21 to 23..I have been useing Kleen with ctain in my fuel but im not sure thats helping...thanks for your replys
where do you get that rev x from
Last edited by redroadrunner27958; Nov 16, 2010 at 08:30 AM. Reason: Automerged Doublepost
Old Nov 16, 2010 | 10:01 AM
Mdub707's Avatar
You can get the rev-x right on this site from the vendors section. Your friend is probably lying to you with mileage. Only a handful of 6.0's have gotten over 20mpg, most are 2x4 and have large injectors and turbos and tuned for it. Is he reading off of the factory console for mileage? It is often referred to as the lie-o-meter just FYI. The only real way to measure is to fill the fuel up into the fill neck so you can see it, drive, and then hand calculate it. Fuel additives really aren't going to get you better mileage. You might have a leaky injector. Hard to tell from here, and you didn't answer all of the questions.
Old Nov 16, 2010 | 12:33 PM
Goose350's Avatar
Try some Rev-x first. Then if that dont help get the truck scanned to see which injectors are going out.
Old Nov 16, 2010 | 10:29 PM
What other question did I not answer I thought I did.I will try and get some rev x first and try.I have a filling I may have a injector leaking but not sure.T hat was why I was asking if any one new the break down on changing these injectors because 2 Dealerships have robed me blind on parts and labor.I can get the same parts for half price or the same as they pay for them,so thats why Im trying to fix this my self.thanks for your response and any more help
Old Nov 19, 2010 | 01:47 PM
ron b's Avatar
it's not too bad to change an injector. You have to remove whatever to get your valve cover off, take the high pressure oil rail off and then you can get to the injector to change it. It all depends on which injector it is, the driver side is easier. The passenger side is a bare to get to the bottom rear bolts on the cover, I had to remove the heat/ac box to remove the cover
BeastFromTheEast
Sep 14, 2015 02:25 PM
BeastFromTheEast
Aug 4, 2015 10:06 AM
slowstroke
For Sale
Apr 1, 2015 11:35 AM
scubasteve12
Mar 29, 2015 09:39 PM
thumperf350
Jan 8, 2015 12:55 AM
