non turbo idi exhaust
Old Nov 15, 2010 | 12:13 PM
Bigred7.3's Avatar
Default non turbo idi exhaust
The way my exhaust it set up now is a 3 inch pipe from the y straight to a single stack. I was thinking about doing a true dual system. I want to remove the factory y pipe and run individual pipes from the manifolds and turn em up in to there own stack in the bed. I plan to turbo the truck eventually so I kno I can't have that set up but for now I want to do it jus to see how it will sound/ perform and jus to say I did it. Tell me what yall think. I'm thinkin ill need to use 2.5 inch pipe to creat the back preaseure
Old Nov 15, 2010 | 02:40 PM
green thang's Avatar
thats the same plans i wanna do
Old Nov 15, 2010 | 04:57 PM
FordDZLMan9191's Avatar
I wanted to do the same thing. I never really looked to see what it would take to do, but since I take my truck out in the hills and play, I didn't want to run the pipe under the frame rail. I thought about cutting out a hole, welding in a piece of pipe, then putting flex pipe on both sides, then running the pipe to the bed outside the frame rail and up.
Like I said, I never really checked into doing it that way but its an idea.
Old Nov 18, 2010 | 09:46 PM
wreckinball's Avatar
You could do something like this...its 4" pipe but you could run it down the frame rails. I have move mine inboard back under to stock placement now but you get the idea. And yeah flex pipe makes life a lot easier.
http://www.ford-trucks.com/forums/me...gnaflow-4.html
this was version 1.1 haha
http://www.ford-trucks.com/forums/me...ck-coated.html
Old Nov 18, 2010 | 09:50 PM
99stackedpowerstroke's Avatar
sounds good man, post pics and let us know what you think if you do do it!!!
Old Dec 5, 2010 | 07:33 PM
93 Indirect Injected's Avatar
pretty sure you dont need that kind of back pressure and besides those factory exhaust manifolds have plenty
Old Dec 5, 2010 | 09:22 PM
these trucks need about as much back pressure as a 50 gallon drum provides. In other words...ZERO needed.
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
D-350 dually
Apr 11, 2015 11:38 PM
schearer350
Feb 12, 2015 12:27 AM
