lights pulse bright and dim while truck runnin?
Old Nov 14, 2010 | 10:30 PM
rjreidhead's Avatar
Default lights pulse bright and dim while truck runnin?
while the truck is runnin even after it warms up the dash light, head light marker light and even the lights in the radio pulse at any rpm. checked power at grid heater and there is no power goin to it so its not cycling on and off. new battery have clean conections voltage regulator only a year old and alt is only 4 months old. the voltage gauge has slight movement in it. grounded block to firewall block to frame and battery to frame and block. any one got any ideas i could try
Old Nov 14, 2010 | 10:34 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
those regulators are junk. i keep one in the glove box all the time.
Old Nov 15, 2010 | 10:35 AM
1stGen1990's Avatar
yeah mine does the same thing. Where is the regulator even at?
Old Nov 15, 2010 | 03:51 PM
cumminskid92's Avatar
It should be on the fire wall on the passenger side. that is where it is at on mine anyways. That sounds like it is your problem
Old Nov 15, 2010 | 08:43 PM
RSWORDS's Avatar
That and the body ground is crap on these trucks. Replace the ground wire from the battery to the core support a good heavy gauge wire.
Old Nov 15, 2010 | 10:30 PM
big bad diesel 416's Avatar
Site Sponsor
when in doubt ground it out I learned that the hard way
Old Nov 18, 2010 | 11:59 AM
blazier18's Avatar
i have a 91 too and my is doing the same thing where exacty is it located?
Old Nov 18, 2010 | 12:28 PM
Vargafarm's Avatar
I replaced my alternator with 1 from PA performance, internal regulator and bolt up.
voltage is rock steady now.
Old Nov 21, 2010 | 10:34 PM
rick390's Avatar
the reg is usually on the fire wall just above the rear valve cover , 2 wire connector with hold down spring , unplug the connector and lights will dim but will be steady , if so reg is junk
Old Nov 26, 2010 | 06:24 AM
92W250's Avatar
I had a similar issue and then went through several regulators. I even replaced the Alternator and crank sensor in pursuit of my issue. Never did get it truly fixed, but at least it charges again.
