rear abs
Old Nov 14, 2010 | 08:17 PM
tedge's Avatar
Default rear abs
Any you out there ever removed the abs unit from the drivers side rear frame rail and just reroute the rear brake line. If i do this will the truck stop better,meaning easier to push the brake pedal in the cab, Read alot of posts about this topic if im going to unplug the abs unit behind the glove box i would like to remove the unit on the frame rail too . Can any one offer any good advice.
Old Nov 14, 2010 | 10:36 PM
Mark Nixon's Avatar
Do it and don't look back.
You will notice the difference immediately.
Be sure you use the PROPER brake fittings and line to do the bypass line.
Mark.
shingi
Off Roading
Sep 30, 2015 11:17 AM
cjt8569
Sep 29, 2015 06:39 PM
Machinist
Jun 23, 2015 06:57 AM
Gitana
Nov 25, 2014 06:25 PM
ValleyF250
Nov 1, 2014 07:56 PM
