low speed binding from stop to 5mph
Hey guys,
I have a 2007 dodge ram 2500 4x4 5.9 with 48re, Just have 93k on it and front end just got all rebuilt and tranny was completely overhauled at 75k. At a stop and as soon as you give the pedal a touch and start moving there is a binding vibratiion you can feel thoruogh the pedal then goes away once speed picks up. only happens at a stop then go situation...also i put the truck rear end up on jack stands then put truck in neutral, went under truck and turned the rear drive shaft and heard slop in transfer case, lot of play back and forth...???? Im trying to narrow down this boise so i can fix it before snow comes??? any help would be appriciated.. Thanks
If you hav a lot of slop in your transfer case thats not normal i had a bearing going out and had a lil slop also just enough to be annoying (1 piece drive shaft) by the way i had sum one rock the truck back and forth and you could hear the clunk also if you looked at the yoke you could see where the yoke was rubbing the seal as it was spining out of round. if you have a 2 piece drive shaft i would check the carrier bearing in the middle and your u-joints.
did they rebuild the transfer case? is the slop in and out on the yoke or up and down? also i had an annoying noise coming from my front driveline...greased it like it says under the hood and that went away? if someone has a manual they can more than likely tell you allowable limits on that transfer case. it will also tell you if end play is adjustable(if its a bearing). good luck!
