fuel leak
Old Nov 13, 2010 | 09:27 PM
dukeboy_318's Avatar
Default fuel leak
Ive got a 99 24v. Noticed a fuel leak coming from the top of the canister. It seems to be coming from around the rubber seal for the fuel heater wires to go into the filter housing. Is there a way to fix this quickly and easily? ?
Old Nov 13, 2010 | 09:36 PM
Remove the fuel heater
Old Nov 13, 2010 | 11:04 PM
How?
Old Nov 14, 2010 | 12:09 AM
Sorry - I confused this with a 12V.
You could go with an aftermarket fuel filter moved to the frame rail and bypass the OEM filter housing. Does your FASS pump not have filters?
Old Nov 14, 2010 | 12:35 AM
Nope its just the pump.
Old Nov 14, 2010 | 02:15 AM
Id think a Racor filter/seperator or a filter head and filter(s). Check out the links on my post here:
https://www.dieselbombers.com/diesel...on-filter.html
Old Dec 2, 2010 | 06:35 PM
J.schiller's Avatar
Did you ever slove this leak ?I have the same leak .
Old Dec 21, 2010 | 07:28 PM
72fj's Avatar
Default fuel heater leak!!!
you can buy the repair kit from cummins it is a fleet gard filter housing do not buy at dodge best if you have a peterbilt/kenworth dealer around give them your eng s/n# on data plate l/front of engine and they can order the oem part.hope this helps 72fj.
Dale9411
Dec 4, 2022 06:51 PM
Dbleo351
Nov 20, 2016 09:34 AM
moneypitk5
Feb 12, 2015 11:01 AM
4x4kingx889
Jan 25, 2015 02:02 PM
Dec 5, 2014 08:30 AM
