Need rear wheel hub for '92 d250
Old Nov 13, 2010 | 04:52 PM
v8440's Avatar
Default Need rear wheel hub for '92 d250
Hi all,
I'm in a bind here. My buddy's '92 d250 had a catastrophic bearing failure. The rear wheel hub on the driver's side had the outer bearing lock up and spin the race in the hub. It ate the hell out of the hub and pulverized the race. So, we need one. It has a dana 70 in it. A hub off a dually will not work-the offset is wrong, and in the case of a '91 dually hub I looked at earlier, the studs are much bigger in the dually and won't fit through the stud holes in the 3/4 ton wheel. If any of you have a hub to sell or know of one, please respond here.
Old Nov 13, 2010 | 09:18 PM
Mark Nixon's Avatar
This really isn't the "place" for this, better in the "Wanted" section.
I've gotten reamed hard for offering help in these settings, but not on DB, so far.
I'd like to keep it that way.
Mark.
Old Nov 13, 2010 | 10:20 PM
v8440's Avatar
Normally I would have posted it there, but this is kind of an emergency. The classifieds are usually looked at much less often than mainstream forums like this. No doubt the parts wanted section would produce results...eventually. Unfortunately, I don't have that kind of time. I need his truck out of my driveway before the 15th coming of Jesus, and he needs it too. Hopefully that will happen.
If you have a hub to sell me please pm me.
cutthroatxxx
Jun 22, 2015 10:16 PM
jag
Tire, Wheel & Suspension
Jan 18, 2015 07:58 PM
