To Buy or Not to Buy...
Old Nov 13, 2010 | 02:12 PM
83chevyk10's Avatar
Default To Buy or Not to Buy...
I'm looking at a 1994 Chevy Silverado 1500 Custom Straight Axle 6.5L Turbo Diesel. Its got 11" Suspension, 3" Body, 180k miles, 10k on trans, dana60 front, 14 bolt rear, 4.10 gears,
44" michelins on 20" thug teflon coated rims, max e-tork programmer, 2 new 1000cca batteries, alternator, starter and fuel pump
extras: line-x bottom half of truck including bumper, fender flares, mirrors, bedrails, westin brush guard, cb/whip, drop-in toolbox, custom steel rear bumper, kc reverse lights, roll cage w/4 kc lights, all rear lights are smoked
trucks also coming with a diesel motor (still trying to get what it is-has bad crank bearing) that will come with the truck. guy wants 7k for it. worth it or not?? i'd be selling my gasser for it...DD either way. any input?
Old Nov 13, 2010 | 02:30 PM
cummins freak's Avatar
DD with 11" lift and a solid axle swap Id pass
Old Nov 13, 2010 | 02:37 PM
83chevyk10's Avatar
even tho i only live 5 minutes from work?? i was contemplating dropping to a 9 or 10" total lift. i shouldn't have to change too much should i? whats an average cost to drop a suspension for a smaller one?
Old Nov 13, 2010 | 03:43 PM
Red_Rattler's Avatar
High Tech Redneck
Take the body lift off and run some 38's... 44's and 410's not a good combo, then maybe. Just gotta look and see how well its built and no cobbled together... Just cause u own a welder doesnt mean u can weld if u kno what I mean. If I lived 5 mins from work I'd walk
Old Nov 13, 2010 | 04:01 PM
83chevyk10's Avatar
i could run the 38's and 4.88's and shouldnt have a problem right? why would you say drop the body lift and not the suspension? is body lift ineffective or just cheaper then dropping suspension?
Old Nov 14, 2010 | 11:03 PM
Crazy's Avatar
think I would pass on it that kind hight on it sure there something on it bent, broken or out wack
Old Nov 14, 2010 | 11:08 PM
Woody35's Avatar
anything over 6 inch lift for a dd would be a deal breaker for me
Old Nov 14, 2010 | 11:09 PM
83chevyk10's Avatar
he said the only things wrong is it doesnt have a front drive shaft and he tried to recharge the A/C and didnt bleed the lines. said once the lines are bled itll be good. i dont use A/C much so if it doesnt work it isnt a big deal to me
i run 9" lift as it is on my k10
Old Nov 14, 2010 | 11:28 PM
Crazy's Avatar
to me 11 inches is just to much bad on drive, front and rear ends trans and even motor but that just what i think
Old Nov 14, 2010 | 11:53 PM
83chevyk10's Avatar
im up for criticisim by all means. i definitely want a lifted truck. i mean even parting this thing out would get me a lot of money. but if this ends up being a truck that is more hassle then its worth ill look for different stuff
