Modifying my AFC
Old Nov 13, 2010 | 12:56 PM
joco12v's Avatar
Default Modifying my AFC
I am modifying and tuning my AFC, is it okay to run an aftermarket fuel plate or should I run the stock fuel plate with an AFC tuning? I have a #11 plate in it already but still have my stock one on hand. Thanks!
Old Nov 13, 2010 | 01:07 PM
brindle_bull's Avatar
its fine to run aftermarket plates...as long as you keep an eye on things like egts and your tranny can hold up to that and the rest of the performance enhancing stuff
Old Nov 13, 2010 | 01:46 PM
blazier18's Avatar
u can do anything u want as long as u got the air to back it up and better airflow out (exhaust) always helps.
Old Nov 13, 2010 | 07:24 PM
joco12v's Avatar
Well I got it all back together, it seems that with my #11 plate in the stock position, I'm not getting much more out of it, even WITH the modified AFC. Move the plate forward?
Old Nov 13, 2010 | 07:30 PM
joshmock's Avatar
the real question here is why NOT? just be careful, don't go breaking nothing and watch your gauges and go for it.
Old Nov 13, 2010 | 07:41 PM
joco12v's Avatar
Nice way to look at it I did read somewhere that not moving the fuel plate makes tuning the afc pointless, I want to know that it is fact before I take it all apart again to move the plate
Old Nov 13, 2010 | 07:52 PM
Smokem's Avatar
That is far from fact.
Old Nov 13, 2010 | 07:54 PM
joco12v's Avatar
Well I have the afc all modified and seems like no matter what adjustments I make the truck runs the same
Old Nov 13, 2010 | 09:51 PM
joshmock's Avatar
what exactly do you mean by modified (be specific with what you did) and that will allow some more knswledgable guys to further assist you. from my experience just moving the stock plate forward should result in a different feeling in the butt dyno
Old Nov 13, 2010 | 10:38 PM
joco12v's Avatar
I turned the cup washers into flat, I shaved off just under 1/8" on the foot, and adjusted the smoke screw to where it just touches the diaphragm shaft. The truck ran good but wouldn't smoke and had turbo lag, couldn't even get 20psi until after 2000rpm. I slowly adjusted the smoke screw and after a couple hours I noticed that the truck is still doing the same, no smoke with turbo lag
