he351vgt
Old Nov 13, 2010 | 12:29 PM
blazier18's Avatar
Default he351vgt
anybody know the numbers on a he351vgt turbo? wat about wiring it on a 98 12 valve
Old Nov 13, 2010 | 06:22 PM
LORDDiESEL's Avatar
you'll need a VGT stand alone.
07.5+ Dodge 6.7L Boost Controller
Sorry that's the wrong link. Fleece performance does make the VGT controler
Last edited by LORDDiESEL; Nov 13, 2010 at 06:22 PM. Reason: Automerged Doublepost
Old Nov 14, 2010 | 01:51 PM
shortbusdriver's Avatar
Good luck getting one for a 12v, Fleece hasnt come out with one yet.
Old Nov 14, 2010 | 06:18 PM
LORDDiESEL's Avatar
The stand alone has variable adjustment parameters to set up the VGT. From what i was told, you can dial it in for any engine around the same CID.
Old Nov 14, 2010 | 06:25 PM
No you cant. Since they tie into a MAP sensor, tps input, and some sort of engine speed pickup they have to be designed for different trucks.
Old Nov 14, 2010 | 06:38 PM
LORDDiESEL's Avatar
Well i know of one other person going to use it for a different app. I plan on using this set up on my 12V.
So i guess you know more than fleece
Old Nov 14, 2010 | 06:45 PM
94 12valve's Avatar
I've seen a spring and a soleinod used very well to control the vgt. the spring works just like a wastegate while the soleinod just works off an on off switch.
Low cost and easy to do
Old Nov 14, 2010 | 08:17 PM
blazier18's Avatar
sounds like alot of trouble
Old Nov 14, 2010 | 08:48 PM
94 12valve's Avatar
not really
Old Nov 14, 2010 | 09:52 PM
blazier18's Avatar
how about money wise i can get a turbo for 300 new
