99 cummins clutch install gone wrong
Old Nov 11, 2010 | 09:02 PM
dylans dad's Avatar
Default 99 cummins clutch install gone wrong
Help needed I just installed a new clutch kit w/ new dodge master and slave cylinder trans went right in no issues there but it will not go in gear while engine is running disk is in corect plate is torqued to 22ft lbs any ideas ? please help need to get back on the road to pay uncle sam
Old Nov 11, 2010 | 09:16 PM
94cummins12v's Avatar
on a bind same thing happened to mine first time i installed take it back out and put it back together little trick i learned is install the clutch/bell housing and slave before tranny have someone push in the clutch so the tranny slides right in much easier. the disk is mostlikely on a bind
Old Nov 11, 2010 | 10:10 PM
Alligator Vinny's Avatar
Site Sponsor - Alligator Performance
Make sure the hydro piston is lined up properly into the receiving cup on the clutch fork. Also on aftermarket hydros there is a black plastic spacer that can be removed to make them work on multiple applications. try removing that spacer and see if that helps. May not be fully disengaging the pressure plate
Old Nov 13, 2010 | 11:08 PM
dukeboy_318's Avatar
Is this a stock replacement kit or an aftermarket clutch? Some aftermarket clutches require either a different clutch fork or the removal of a spacer behing the pivot ball that the forks mount to
JoeyMiR
9
Feb 3, 2018 10:05 PM
twinturbo12v
Price Quote - Request A Price
Oct 6, 2015 07:30 PM
lkfldredneck
Jun 25, 2015 04:51 PM
Cody Cain
Dec 22, 2014 01:27 PM
Cody Cain
Dec 21, 2014 06:50 PM
