transfer Case, 4x4 Not Working
Old Nov 10, 2010 | 08:48 PM
BigRedMudder's Avatar
Default transfer Case, 4x4 Not Working
when i put the transfer case in 4 high or 4 low it engages in the transfer case but i dont have 4x4 and the light on the dash does not come on? and i pulled the vacum line off of the front diff and its not getting any thing.. could it be the solinoid that is goes into at the back of transfer case? and does anyone know whats that called?
thanks
Brad
Old Nov 10, 2010 | 09:15 PM
rippershifter's Avatar
I would follow my vaccum lines all the way back to the t-case. Sometimes the rubber boots where the steel lines connect to the rubber swell up and leak or come off all together.. I just noticed you said vaccum line, theres 2 lines one holds the actuator fork in 4wd the other out. make sure you were checking the right one for vaccum..
Old Nov 11, 2010 | 05:44 PM
yj junker's Avatar
change it to a posiloc system and be done with the work sometime vaccum system
here is a link 4x4 Posi-Lok - 4WD Engagement Systems
Old Nov 12, 2010 | 12:10 PM
Hyrdgun's Avatar
I just had the same problem. On top of the transfer case is a 4wd actuator switch. It is where all the vacuum lines come together to supply vacuum to the differential. Ordered mine from LMCTruck.com. $22 after shipping.
Old Nov 12, 2010 | 12:15 PM
1AMatt's Avatar
Site Sponsor - 1aauto
I agree... The posi lock system is definately the way to go on any 4x4 chrysler with a two piece passenger shaft. You will never have to worry about your 4x4 not engaging ever again!!
Old Dec 22, 2010 | 09:30 AM
tyler h's Avatar
mine was the accuator. its like 20.00 dollars at oreillys.
Old Dec 7, 2011 | 01:53 PM
mabry1's Avatar
I'm having a similar problem, my truck shifts into 4hi and my light comes on but isn't ingageing? I have good vacuum at the front axle. Any tips to try??
Old Dec 8, 2011 | 09:05 PM
luke46's Avatar
Just had this happen actually still waiting on my kit from alloy. transfer case would lock in but axle wouldn't it would randomly shift. Turns out to be actuator on transfer case. So temporarily to be able to drive it ran vacuum from the tee in the engine compartment to the disconnect side of the CAD central axle disconnect. If I need four wheel drive I just have to lock in the transfer case and switch the vacuum line to the other side. It works for now kit should be here tomorrow.
dezeldoc
Wanted To Buy (WTB) - Used
Jan 27, 2016 05:08 PM
Spaky6.0mudder
Aug 4, 2015 08:29 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
steves2500diesel
Oct 14, 2014 05:36 PM
