sloppy steering
Old Nov 10, 2010 | 08:18 PM
dan33klein's Avatar
Default sloppy steering
ok guys, i know the stock steering on a dodge sucks. and i already know about the hydro assist for 800$ i could get, but with money being an issue i didnt know if there was any tips.
my steering box has so much slop in it, like over 90* of slop in the wheel, it is all tight to the steering gear, so thats my culprit. i have a new pitman arm and tie rod ends. steering gears the problem. is there anything that can be done to tighten it up? im good friends with a guy that owns a junkyard. i was just going to go out there and turn the wheels on some wrecked trucks out there and find the best one and hopefully get it for cheaap. i think anythings about better than what i have now so its worth a shot. does anyone know if they ram the same gears in 1/2 tons? if they did there would pry be in better condition than a heavy 3/4 ton, especially with the cummins, any helps appreciated
Old Nov 11, 2010 | 02:01 PM
jrad989's Avatar
New steering box, steering stabilizer bar, tie rod ends, other linkages. Thos big tires are gonna go through ball joints and **** so fast its not funny.
Old Nov 11, 2010 | 02:41 PM
dan33klein's Avatar
i have 3 new steering stablizers, new tie rods, new pitman arm, new ball joints
Old Nov 11, 2010 | 03:04 PM
gonekrazy97's Avatar
there is an allen head bolt on the top of the stearing box with a nut that you can tighten i did it to mine and it helped a little but i was on all data the other day and printed out the whole procedure on how to tighten all the bearings up so if you want that i can scan it up
Old Nov 11, 2010 | 05:04 PM
tiremann9669's Avatar
New steering box, steering box brace, have you replaced the steering shaft from the column ? stock ones are junk
Old Nov 11, 2010 | 08:50 PM
Drothgeb's Avatar
I've got a Red Head steering gear, it's a lot better than the stock ones.
Or, you can get the gear and shaft from Borgeson, they're very good, but pricey.
Old Nov 12, 2010 | 02:39 PM
dan33klein's Avatar
The shafts tight with no play all the way into the box. So the shaft should be good
Old Nov 13, 2010 | 12:15 PM
zjohnsonua's Avatar
I had the same problem. I cheaped out and put a Cardone gear in mine. Its done well and was $180ish. The 1/2 tons aren't the same as ours because of the cummins.
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
