truck stuck in liimp mode...
Old Nov 10, 2010 | 08:10 PM
bullfrog8813's Avatar
Default truck stuck in liimp mode...
Get p0973 for code. I clear it and it comes right back. How do I make it go away. Is it the governor pressure sensor or what... its the low circut voltage somethin or another code. I know which plug it is on the transmission. Need the fix. Gonna trade it off and it did this while it was bein test drove. I replaced the neutral safety switch and same thing...
Ivee searched on here and not found any solutions. I can't be the only one with this code
Last edited by bullfrog8813; Nov 10, 2010 at 08:10 PM. Reason: Automerged Doublepost
Old Nov 16, 2010 | 10:00 AM
goodolboy's Avatar
check every fuse and relay i had that excat thing happen here in iraq on an m-rap made by sterling but it was only a relay switch between the motor and trans. there is a relay that when you turn the engine on the stater says its ready then the engine then the transmition that might be the problem.
Daniel Leipart
Jun 28, 2015 02:42 PM
Gm3500
May 7, 2015 11:01 AM
syctaz
Mar 3, 2015 09:23 AM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
