Bosch 300hp marine injectors
Old Nov 10, 2010 | 07:41 PM
rippershifter's Avatar
Default Bosch 300hp marine injectors
Is anyone running these injectors?? I was thinking of getting them because they are Bosch Injectors so the quality must be there, but wanted to know what kind of power increase I can expect from them??
Old Nov 10, 2010 | 09:18 PM
kazairl's Avatar
Kind of confused on what your asking here.
I've heard of 370 Marine injectors for 12v valves
and I've heard of RV275 injectors referred to as 300 hp injectors. But those are from the RV engine and not a marine engine.
Old Nov 10, 2010 | 09:28 PM
http://www.thedieselstore.com/templa...VehNum=1112594
Old Nov 10, 2010 | 09:57 PM
sstockton's Avatar
I ran a set of them for a while. They were a nice little injector with a stock charger and a box. Egt's could be kept manageable but they were also fun to drive. Probably about a 50hp gain maybe.
Sean
Old Nov 11, 2010 | 07:01 AM
Rooster24v's Avatar
Sean
took the words right out of my mouth!!
Old Nov 11, 2010 | 10:54 AM
kazairl's Avatar
Those are Rv275 injectors. When combined with a timing only box like an Edge EZ they will bump your engine HP to about 300hp. Which is why they are called 300hp injectors.
Old Nov 12, 2010 | 01:25 AM
01quadcab's Avatar
should be a good injector these should be a step above rv275's if they are the right ones 300hp rated motor at crank just like rv275's are 275hp rated at crank.
Old Nov 12, 2010 | 09:27 AM
kazairl's Avatar
AFAIK Cummins never offered the 24v with the vp44 as a marine engine. DO have proof to the contrary?
Do a search for rv275 injectors. Every place that sells them lists the same part number for them as the "300hp marine" injectors listed above.
If there is indeed a 300hp Marine engine, then it is not rated at 300hp because of the injectors.
You'll gain about 40 hp using these injectors.
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
Original_big_rod
Feb 24, 2015 10:39 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
jkidd
For Sale
Dec 9, 2014 12:33 PM
