New Cummins Owner
Old Nov 9, 2010 | 10:05 PM
John E's Avatar
Default New Cummins Owner
New Cummins owner here, quick question.
I have a 2004 1/2 Cummins, only 52k miles. Truck has no muffler and the K&N filter.
Truck seems not to make much power and poor fuel mileage averaging 13 mpg mixing city and hwy, I owned a 2005 Ford 6.0 before this. The Ford was good on power but I had head gasket and turbo problems. I had the Dodge at a shop that checked "injection pressure, rail pressure and fuel pump pressure". All were meeting factory spec except for the fuel pump, down 3 lbs. Recommended I get an aftermarket lift pump. I have heard yes on aftermarket and it really doesn't matter.
The truck is used for hauling a 28 ft car trailer with 3200lb car, golf cart and tools as wells as a 29 ft travel trailer. Just need the truck to work well, not be a hot rod.
Ideas???
Thanks
John
Old Nov 9, 2010 | 10:19 PM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
First off welcome to the forum.
Yes the 04.5 Cr's had a lift pump on the back on the fuel filter bowl that would fail. Dodges fix was know as the retro-fit kit that relocated it to the tank. Personaly with how crapy our fuel is in this country I'd put an Airdog or Fass fuel system with filters. Much better pump than the dodge retro fit and better filtration than the factory filter.
Get rid of the K&N filter and either put an AFE or S&B with a dry filter.
How does the truck start? Pop right off or crank awhile? I don't care what idle pressure is at the high side but what is cranking pressure? These truck have an issue with sticking injectors.
Old Nov 10, 2010 | 06:01 PM
John E's Avatar
Thanks for the feedback
Truck starts excellent.
Do I replace the filter element only (K&N)
As far as the lift pump. Do you have any part numbers for the aftermarket pumps.
Good info thank you
John
Old Nov 12, 2010 | 01:39 AM
Sirwrenchiezolot's Avatar
I like my K&N havent had any probs with it
Old Nov 20, 2010 | 12:57 PM
cummins army's Avatar
just order the airdog with filters you can get the 150ghp it never hurts to have the extra fuel to lubricate everything i had the airdog 150 on my 02 and loved it never came below 15psi at the injector pump air dog 150 all the way and easy to instal
Old Nov 20, 2010 | 07:27 PM
crzycummins's Avatar
if you want to go that route post in the price quote section from our sponsors and they can get ya set up
Dynaholic
Aug 19, 2015 11:50 PM
Dynaholic
Diesel Engine Conversions
Aug 14, 2015 02:11 AM
Dynaholic
Aug 14, 2015 02:09 AM
LittleBuck
23
May 21, 2015 06:06 PM
Dcummins24
Jan 3, 2015 07:37 PM
