What size injectors to go with a super b special?
Old Nov 9, 2010 | 07:16 PM
blowin smoke 1's Avatar
Default What size injectors to go with a super b special?
What would be a good injector to go with the special turbo?I finally put my 150s in and they haul *** and egt's are 1400 max.I would like even bigger injectors when I put the turbo on.I would like to keep egts in check too if its possible.Injectors are by far the best upgrade!
Old Nov 9, 2010 | 07:28 PM
Farmboy 2.0's Avatar
I would just keep those injectors for the super b special i think it would be a efficient running truck that would run pretty cool.
Old Nov 9, 2010 | 07:52 PM
kingbrad89's Avatar
Agreed. Check out my sig. Truck runs great. The bigger the injector the hotter it's gonna run, wouldn't go over 150's without compounds
Old Nov 9, 2010 | 08:08 PM
RAW's Avatar
RAW
What kind of 150's do you have? Any programmer? I can't see signatures on my BlackBerry.
I'd say 150's are the right size to keep driveability and some mileage.
Old Nov 9, 2010 | 08:25 PM
Ddp 150 s and my mpgs did go up to 14 to 16 on first tank!
Old Nov 12, 2010 | 01:32 AM
01quadcab's Avatar
depending on what you do with the truck I am sure you could go with some 200's. I ran them with my 62 it would street drive fine but couldn't tow anything. But you have more air so should work well.
Old Nov 12, 2010 | 12:43 PM
I run 220's with a 62 and its fine on the street. But gets a little toasty when i tow with it
Old Nov 12, 2010 | 03:40 PM
24vcumminscowboy's Avatar
did you put the 150s in with ur stock turbo the reason im asking is because im going to get an edge comp and was thinking about throwing some 125 nozzles on but im alittle afraid my turbo will blow up b4 i get the cash for a bigger turbo
Old Nov 12, 2010 | 07:48 PM
01quadcab's Avatar
if you plan on anything over 100hp on a stock turbo your asking for turbo issues
Old Nov 12, 2010 | 08:13 PM
thanks 01 thats was i was worried about ill hold off on the injectors till i have the money for the turbo as well
