heater grid relay
Old Nov 9, 2010 | 10:01 AM
cumminspwr11's Avatar
Default heater grid relay
last year my truck had a wired electrical issue were everything electriconic got fried, the intake that bolts to the heater grid got so hot that the paint was bubbling up on it so i unhooked the relays as a safety measure- well now it is finally getting cold here and my truck doesnt like to start to well, last winter i plugged it in every night and it started fine, i think i have a bad IP because i have checked my injectors and even changed them and it still has the same problem
can i use a glow plug relay for a 7.3 to run my heater grid or should i find factory replacement ones?
Old Dec 31, 2010 | 07:33 AM
glfredrick's Avatar
The relays are simple on/off units that can be replaced with a generic starter relay for under $10 each. Usually older Fords or Jeeps will work.
Make sure the type relay you get doesn't ground through the case though. I got some and they did that -- Dodge does all its switching through grounds intstead of hot wires, so a grounded relay will switch the system. I mounted mine on some insulated material to break the circuit.
dodge2014
Apr 16, 2015 08:54 PM
robbyS
Apr 16, 2015 02:22 PM
95 cummin
Jan 21, 2015 11:54 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
justinsbeck
Nov 22, 2014 03:03 AM
